Tracing PCB ground loops
not really, there is another source of hum wich is sometimes incorrectly called groundloop, and that is current running through a coniductor that is also part of a signal loop, for example a feedback path;
than can be found by injecting a current between 2 ground connections, for example the input and output ground of an amplifier system, and then listen or measure the resulting hum. mixing panels alwasy are problematic as the summing amplifier has a large gain for any voltage appearing in a ground conductor.
Reactions: popeman
The reason I'm asking is because I have a PCB where I get a bit of hum at 50Hz and I'd like to trace where it's coming from. I tried the same PCB with a different PS but the result was very similar (actually a bit higher hum) so I think it might be the PCB itself that cause this hum.
It is not audible, it's pretty low but it is there indeed and I'd like to eliminate it.
Can you post the schematic, and a photo? However, a 50Hz hum is more likely to be inductive coupling, rather than galvanic coupling,
unless you use a half wave rectifier.
Unfortunately I don't have a schematic. It's some unkown diy inductor eq that i got for cheap. Not much info. as I said, it's not a big issue, I can leave with that since it's not really audible.
My question about tracing ground loops on PCBs is mostly for academic reasons and also because I design some PCBs from time to time so it would be nice to know.
