I have Trace Eliot H 100 on my bench, I have no filament voltage on the 12 AX 7s. The traces on the Bridge Rectifier were burnt up for The 24 volt rail which I repaired . In this particular amp , it uses 12.6 volts DC for the tube filaments. Which I believe comes in on pins 4 & 5 of the 12AX7s. The schematic isnt real clear on this . I replaced all of the 1N4002s diodes I now have 32 volts but it's not getting to the 7824 voltage regulator is it was shorted when I pulled it out ever so slowly ,but it broke a trace on the top side of the board when I pulled it out , which I tried my best to repair. I m still not getting my 24 vdc for the filiments. I will check continuity again between C 12,13 & 14 --and the pins of the 7824. Something right in there is funky ... And not in a good way. If anyone has any input on this issue , please let me know. Thanks so much.
