Hi, folks have been recommending a 2.5k as optimal cross for beyma150/150H with MT design. Anyone has access to crossover schematics that can enable a passive upper monitor with 10/12 inch mid?
Are you aiming for flat response or will you EQ things down afterwards, in other words, do you mainly need overload protection?
If the first applies: it isn’t that simple. You can’t take some crossover from the shelf and assume it turns out right. And honestly, if you’re willing to spend big money on these drivers, any attention to crossover and enclosure design seems mandatory to me.
Not my intent. Really want to know if it's done and how it sounds and if the baffle size is workable. It could also be an easy solution
