TPA3116D2 Power Supply
I've used this board in a number of projects. The 2.1 claims 100w + 50w x2. So far I've been using a 19.4V (130 watt) laptop brick for power - 19.4V doesn't max the output but it does a job. Because I like recycling and I NEED to LEARN I've wondering if I can build a rudimentary out of the crap in my junk box.
I have a transformer from a BOSE Companion Series 5 - 18.5v (26v). BOSE claim the system is 300w but I'm guessing it's maybe 80-100VA?
I have a LVA10433 board from a JVC System.
Can I salvage enough parts to make rudimentary power supply?
TBH if the laptop supply is giving you enough power why change?
If you need a more powerful supply and insist on building it then you need to be sure the transformer is large enough and that you are confident with mains wiring.
I wouldn´t.
Rated power in most Class D power amps comes at a voltage very close to absolute maximum (destructive) rating.
Example: TPA3118 puts out rated power with a 26VDC supply, but absolute maximum is 30VDC
If using an SMPS which is tightly regulated by design, no big deal, you will have those 26V (within 5% or better) at any load from zero to full overdriven output.
But in a conventional unregulated mains > transformer > diodes > caps supply, voltge from unloaded to dull can easily vary 15-20%
So you either have higher than 30V idle (dangerous) to guarantee 26V @ full load or you have safe 26V at idle but ghen quite a lot less than that at full load ... which will cut available power big time, and perform much worse than an SMPS.
Yes, "doable" ..... but what´s the point?
and w.t.h. is an LVA10433? 😉
"Salvaging"???
May be ... is any electrolytic there of a useful value?
Heatsink looks usable for a TDA2030 or LM1875 amp.
The rest?
Unusable dumpster quality stuff.
