Toslink transmitter replacement help
I have a broken toslink transmitter and need a replacement. The number on the transmitter is 501T 0X. I can't seem to find a transmitter that has the same pin position as this one. The solder pins are in front of the plastic mounting pins. Everything that I have found so far has the solder pins behind the plastic mounting pins. This is for a Denon car CD player...and Denon doesn't have a clue.
