Hello Everyone.
I'm new to the forum and new to diy audio in general.
This year I decided to build a portable stereo "boom box".
This is the amp and speakers I used:
Wondom AA-AC11162 2x50W 4-8 Ohm Class D Audio Amplifier Board BT4.0
Dayton Audio DC160S-4 6-1/2" Classic Shielded Woofer 4 Ohm
Dayton Audio ND20FB-4 Rear-Mount 3/4" Soft Dome Neodymium Tweeter
The crossover is a 2nd Order Linkwitz-Riley at 3600Hz:
Dayton Audio DMPC-5.6 5.6uF 250V Polypropylene Capacitor
Dayton Audio 0.35mH 20 AWG Air Core Inductor Crossover Coil
The speaker has plenty of output and I'm really pleased with it overall.
However, I really want to boost the bass.
I used WinAmp to cut all frequencies above 70Hz as much as the EQ will allow and it sounds how I want it to.
I would like to make the speaker/amp combo replicate this result.
So my question is do I need to rebuild my crossovers differently?
Also, I read somewhere that someone had cut the treble at the volume pot to create bass boost.
I really have no idea where to even begin to correct this.
Thanks for any advice.
May be a QUAD-like tilt control would suit your purpose.
This might or might not help:Implement an audio-frequency tilt-equalizer filter | EDN
Thanks for the quick replies.
The tweeter is not actually that loud in this setup. Really, I'm just lacking significant bass from the woofer. As stated in the original post, a low pass shelf EQ corrects the issue.
After some searching based on variable loudness pot, I think this might be what I'm looking for:
http://www.diyaudio.com/forums/analog-line-level/202413-loudness-stage.html#post3118059
Of course the idea creates more questions. The schematic shows 4 connections to the circuit right? I understand the ground but not the rest.
So this could be implemented inline with my current volume pot? On the output side?
Also, I would need 2 of these for stereo?
I apologize for my ignorance in this field. I've not had much experience with schematics, and building circuitry.
EDIT:
I see further in the post I linked they are answering the additional questions I posted.
I will likely try to integrate this circuit in my design and get back to you all with the results.
Also, any additional ideas or advice is certainly welcome.
EDIT:
A typical loudness circuit boosts bass and treble so from your first post I gathered that you want to keep treble low which made me think of the tilt control instead.
Thanks for replying.
At first I had evenly cut all the frequencies above 70Hz using WinAmp's 10 band EQ and achieved good results.
However, after finding the post on the variable loudness pot, I recreated the EQ curve shown and it improved the overall sound even more.
Also, I did take a brief look at the link you provided. I'll give it a read when I have some more time.
Hi, you could use this to give low frequency boost Sub-Woofer Controller also look into baffle step correction
Interesting piece of equipment. Thanks for the input.
- Tone Control or Bass Boost?
