I need some help with a TOA W906-A amplifier as it keeps blowing the 3amp fast blow fuse. It is rated at 60w RMS and 100w peak. It's an old amp at my school and we are trying to get it up and working again. I think that there is a short somewhere on the boards, it looks like a complicated set up as there is an Eq and everything, I need help narrowing what boards would have the fault, any suspect components. I have the service manual and the part numbers I just need some help on finding the faulty components. If I put in a new fuse the amp turns on with no load attached, then blows about 5 seconds later when the amp engages. The manuals are attached, if they are any help.
ajm14120 said:The manuals are attached, if they are any help.
Please try again, I'll gladly have a look.
Let me know if you have trouble posting them.
/Hugo
First, disconnect the mains transformer from the Module Power Supply PCB and Condenser PCB to rule out the transformer.
If the fuses still pops, you don't need to look any further.
If it doesn't, measure the bridge rectifier D901 and suspect the capacitors on the Condenser PCB.
If these are fine, proceed with the output transistors Q901, Q902.
/Hugo
/Hugo
Use a light bulb in series with an AC cord to feed it power or use a variac.
Its been a while since I seen one but I believe the power amplifier portion can be separated via connectors to allow checking of the mix and EQ sections. If they come up and run ok then the problem is in the power amplifier module. If I remember correctly there is an op amp (8 pin dip) that can go bad when you overdrive the amp and cause it to take the fuse. Somewhere around my shop is a service manual and if I can find it maybe I can be of more help.
This is one of Toa's models of lesser value. Its meant to be a 60 watt amplifier with zero headroom. Don't count on 100 watt peaks
because this is one amp that will lunch if you try it.
This probably belongs in the solid state forum because it is not a chip amp but a in wall oscillator.
This surely doesn't belong in the chip amp section because it is a commercial piece without chip amps.
