I have a headphone amp built by an article in Glass audio,Brute Force.I am not using a regulated power supply,what are the improvements if I use a tube regulated supply?
ryssen said:I have a headphone amp built by an article in Glass audio,Brute Force.I am not using a regulated power supply,what are the improvements if I use a tube regulated supply?
Without seeing the schematic, it's difficult to tell what, if any, benefit there would be to a regulated supply. One thing to keep in mind though, if you're using pentodes, if you regulate the B+, you also need to regulate the screen grid supply...
Peace
I suppose this is the one:
BRUTE FORCE BY ERIC BARBOUR.
BTW, never had any noise from a glowdischarge tube...
Maybe it's just some OD3s?
It sure is brute force with a //ed 6BL7 and 12SN7...and they call it minimalism? Hmmm...
Cheers,😉
Cheers,😉
