TL Nelson Pass
I built the Nelson Pass TL, with the Pioneer B20FU20-51FW following this plan: file:///home/martin/Downloads/Pass-BOFU-TL-map-300408.pdf
Great bass, I recently added some ESS AMT tweeters cut with a 2Mf capacitor. I will try to cut lower the ess around 2500-3500 hz, I appreciate your suggestions, thanks
I'm using them with Monarchy SM-70 amplifier.
an old thread about TL PASS
  • Pass-BOFU-TL-map-300408.pdf
Reactions: Arthur Jackson
Trim 1/4 of the whizzer off..................
Sounded less "honky" to me.
And some cotton balls separated out between cone and whizzer, known as the 98 cent tweak
"That's the famous "98 cent tweak"; just take a piece of Acoustistuff or polyfill and make a somewhat elongated cotton ball of it. Then gently wrap it around the outside of the whizzer."
https://db.audioasylum.com/mhtml/m....hlight=damar+98&r=&search_url=/cgi/search.mpl
Seeing the measurably higher qts than manufacturer's, I wonder if this box can work for the w8 2145 ?
