tl 084 scheme questions
I've build a 1 in 4 distribution amp with TL084 , but my scheme seems to be wrong , because I have problems when I turn it on. here is the scheme :
but I have strange problems , actially only one:
just one op.amp TL084 repeats the audio signal just fine. but when I put another for the another channel I become a mono effect(the balance control doesn't work) and strenge mixing and losing some high or low frequences.
Actually I just need to split the signal from my soundcard into 5.
Can someone help me!
Thank You!
