I would like to know if there are any fuses inside the Tivoli Model One radio. I am trying to diagnose a problem for a friend.
Moderator: I posted this same request at the end of another post but thought it more appropriate that I start a new thread. Please remove as you see fit.
Edit:
Just found out the unit powers on and gets am and aux works but no matter various antennae can't get fm signal.
sorry for the confusion and thanks for any input.
I may have to start a new thread to get this moving.
I have a Tivoli pal and had problems as well (not with the fm section though) I did find bad solders in mine (particularly the speaker connector. It worked fine for years then stopped). I would take the radio apart and check that the connections are solid between the various boards and also look closely at the tuner section for loose conections. For as good as these radios sound, they are pretty simple inside.
