Hello everyone,
I have a David Clark (H9940) headset with the following pin configuration:
https://www.davidclarkcompany.com/files/partslists/pdf/PL19539P-95.pdf
My plan is to wire the pins from the headset to RCA plugs that can connect to the UCA222. However, I'm looking for some guidance on the specifics:
Thanks in advance for your help!
- RT ear
- Ground
- LT ear
- Sens
- Mic Hi
- Mic Low
- Shield
- How should I wire the RT ear, LT ear, and ground to the RCA plugs?
- How do I handle the microphone signals (Mic Hi, Mic Low, and Shield) in this setup?
- Are there any additional components or considerations I should be aware of to ensure proper functionality?
- The required voltage levels for the microphone input.
- How to implement impedance control in this configuration.
