Tips for replacing LME49600TS on Legato
You'll probably want to use the largest nozzle.
Hot air rework takes some practice to get right. I would suggest getting a scrap piece of bare PCB and some cheap TO-220 devices like voltage regs and practice soldering and unsoldering some first. You can go one step further and actually try and power up the reg after the soldering routine to see if it survived.
I can't say exactly what temp you will need; I don't know if lead free solder was used or what type of paste you will end up buying. It will need to be hotter to take them off then it will be to melt the new paste though. The datasheet for the buffers says a max of 260C for 10 seconds, though I find that's usually fairly conservative.
I have some LME49600 and the practice materials mentioned if you're interested, just send me a PM.
