Time to rock your world.
Enough pussyfooting around with these wimpy 300B SE "amps". Try this motha on for size!
:bigeyes:
Power supply is here:
- There are a few bugs (I think) that have to be ironed out. Try to spot them 🙂 (There's plenty of time for that while I rewind the MOTs..)
Tim
Those Trafos will NOT, NOT be low priced
Those Trafos will NOT, NOT be low priced,
if I ever get to find them ...
so I stay Happily Solid Discrete
like most people of the world
when it comes to POWER amps
Happy building, Sch3mat1c
You will be one of a few 😉 (lucky?)
/halo - main stream artist ... 😎 😉 😎 and Happy
Sch3mat1c said:
Actually, I only intend to spend maybe $100 total...
[Dramatic pause while everyone passes out]
Only iron I'm going to buy is the filament trannies..the HV PT and OPT I'll wind on Microwave Oven Transformer cores.
*=- All Hail The Mighty Junk Pile -=* 😀
Tim
An excellent approach.
I have long thought that 6146 has been overlooked; I have a few that I was going to use in a 40W guitar amp; I have all the parts I need, except time.
[And yes I know that Ampeg used them in the early SVT]
Keep us posted
7N7
I am sorry...
Tim
I am sorry.
I had no idea, you can build a TUBE power amp
of that kind - with low money. 😎
This is what happens, when I speak of things
I only "think I know"
but do NOT, in fact, know so much about.
Good Luck with an interesting TUBE project
Sch3mat1c 🙂
/halo - have to learn more 🙄
I tried a 6L6GC (new) as pass tube in my preamp PSU but the only thing I got was a blue flash inside it, along with some noise (tik). Replaced with an old EL34 and it went ok. I am also using a zener (man this one was hard!!) instead of the 0B2. Anyway, that thing is not perfect, as I need 1000uF to get rid of the hum after retification (around 180V).
I'm not going to worry about the 6L6. They're used all the time in guitar amps at 500V, meaning peak plate voltage is up to 1kV (much more if it does a flyback pulse somehow), and they manage to last a few gigs apparently... 🙂
(And besides, I'm gonna use my pair of EL34 in something else 😎 )
1000uF eh? Sounds like you must've had either ground loop or you forgot your PS choke...
Tim
Hehe. No PSU choke indeed. Those things cost money and I could not find one in the junk store. Anyway how can a choke be differentiated from a transformer (I mean in a big pile of junk)? Number of wires coming from it - 2 instead of >4?
***Jan Rowland, Roll Your Own Power Transformers:
http://members.tripod.com/~schematics/xform/xformer1.htm
***Patrick Turner, Output Transformer Design Calculations:
http://www.turneraudio.com.au/htmlwebpgs02/optdesigncalcs.htm
*******ransformer Basics, from Lessons in Electric Circuits:
http://www.ibiblio.org/obp/electricCircuits/AC/AC_9.html
***Determining OP Transformer Impedance:
http://www.geocities.com/vintage_radio/outimp.htm
***Basics of Inductors:
http://www.hills2.u-net.com/electron/induct.htm
* VoltSecond and Mike Lefevre, What does the Transformer Inductance do
to the Loadline of the Tube?
http://www.siteswithstyle.com/voltsecond/211_Load_lines/211_LOAD_LINE.html
✔Gabe Velez, Transformers:
http://members.tripod.com/~gabevee/transform.html
* Michael LaFevre, Transformers and Phase Shift:
http://www.magnequest.com/tech2.htm
* Color codes (MarVac Electronics):
http://www.marvac.com/funpages/chokes.htm
* University of Surrey, Producing Wound Components
http://www.ee.surrey.ac.uk/Workshop/advice/coils/#turn
* David Berning, An Audio Amplifier Design Philosophy:
http://www.meta-gizmo.com/Tri/otlology/BERNINGS.htm
✔Randall Aiken, OPT's Explained
http://www.aikenamps.com/OutputTransformers.html
* Richard Sears, Trany Math:
http://richard984.tripod.com/transformer_math.htm
* Lundahl, Technical Papers from Lundahl: very short pieces from
Lundahl lab: http://www.lundahl.se/papers.html
* Pete Millett, Power Transformers for Audio Equipment:
http://www.pmillett.addr.com/images/ax_power.pdf
* VoltSecond, Damping Ringing in LC Circuits:
http://www.siteswithstyle.com/VoltSecond/Damping_ringing_XFMRS/Damping_ringing_in_xfmrs.html
* Plitron Site:http://www.plitron.com/Pages/sitemap.htm. Link takes
you to site index. Under "Publications". A collection of articles
including:
-Secrets of Output Transformers, Menno Van de Veen
-Measuring OPT Performance, Menno Van der Veen
-Theory and Practice Of Widebandwidth Toroidal OPT, Menno Van der Veen
-Modeling Power Tubes and their Interaction with OPT, Menno Van der
Veen
* John Atwood (One Electron), Transformer Measurements:
http://www.one-electron.com/Trans_Tests.html
* Max Robinson, Understanding the Transformer:
http://www.angelfire.com/electronic/funwithtubes/Amp-Transformers.html
*** Dean P Currier, A Biographical History of Induction Coils:
http://radiantslab.com/quackmed/Deanbio.html
*** Edcor, Transformer Tek Notes:
http://www.edcorusa.com/gadgeteer/tek-notes_xformer.htm
Toroid Corp. of Maryland Tech.Bull. #1 ( Application Notes on
Rectifier Transformers) and #2 (International Line Voltages and
Frequencies): http://www.toroid.com/technica.htm
all that from other fellow RAT
Is the 330 ohm value in the diff amp cathode circuit correct? Seems like that won't give you much compliance at the swings you'll need for that stage. Why not a ccs or a bigger resistor to a negative rail? And the return of the vr tube in that same stage seems odd; I would think that the distortion would be lower if you used separate returns directly from each screen to the corresponding cathode using a vr or a zener-type circuit.
You may find that you'll need some compensation in the open loop circuit, since you've got a whole pile of HF rollofs which might make stability marginal; an RC across the plate resistor of the input stage will allow stabilization of the closed loop a bit more easily. You might also find that, especially with home-wound stuff, you've got to put a compensation capacitor across the side of the p-p corresponding to the inner windings of the output transformer.
The 6146 is a damn rugged tube and easy to drive. Good choice.
Yes, the 330 ohm is correct. It will only drop 10V, but with the high Gm of the 6CL6s, will correct distortions well. Since it is a common-mode part, it will not reduce the gain of the stage, while canceling unbalanced noises. A CCS seems an unnecessary complication, and the 40mA draw on the negative supply would be too much for it as shown.
Hmm, I suppose I could return the 0D3 to the 330 ohm resistor instead. Otherwise, I could indeed return each to its respective cathode, and use RC connection instead. (Really, I just wanted to throw in the 0D3 cuz' it looks cool 😎 😉 )
I'll muck around with stability issues when I build it. I hear it isn't quite a predictable thing to model anyway.
And, of course I'll put a Zobel(?) across the OPT 🙂 I recommend everyone do that...send a 1-10kHz square wave through the amp, and try different Rs and Cs until it looks right. Really helped the oscillographilogical appearance of my 6L6GC SE amp.
Tim
It's not so much a Zobel, but rather the need to set a dominant pole at a frequency at least a decade lower than the other rolloffs to ensure closed-loop stability. That's why it's easiest to do it at the first stage. And you probably won't need that RC across the output transformer in that event, which is a good thing considering the relative AC currents between the first stage and the output.
20 mils per side on the driver is probably more than you need- the input capacitance of the pentode O/P stage won't be too excessive, and a cathode or source follower would be a better option if you want to drive the O/P stage into grid current.
Sure, I could use a 12AT7 (as plate follower) for the last stage, and it would work perfectly. But it would look so damn weak! 😎 :devily:
OTOH, maybe I could make an amp with just that - call it The Contrast, use a 6AL5 for bias supply and my RK-836 (ST-16, woot) for power supply (I only have one, so I'm not sure how I'll get around the unbalanced supply...). 12AT7 LTP splitter with 24A in negative-resistance region for CCS (oh yeah, gotta add that to the CCS thread), and maybe a quad of 6AQ5 for output.
Tim
Wrecking my printer
Choky,
I am going to blame you for wrecking my printer by forcing me to print out a number of those excellent transformer references. I've had a quick look, and the University of Surrey reference is a nice introduction, and the Patrick Turner looks very practical.
Thank you.
