Thunderdrive Deluxe Pedal Build Demonstration From ModKitsDiy - YouTube
The Thunderdrive Deluxe is an overdrive pedal kit that will provide a strong clean signal boost in the early gain settings and smooth distortion at maximum gain settings.
Adjusting volume control and gain controls provides a wide variety of tones in spite of it's simple contruction. The Turbo switch provides an additional boost in volume and less internally generated distortion. The pre-painted black enclosure, red control knobs and red LED indicator give the Thunderdrive Deluxe an understated attractive finish. It is capable of overdriving the preamp section of your guitar amp or adding it's own layer of distortion at lower volume.
This is an easy build kit with point to point wiring and clear, easy to follow instructions.
The current draw of this pedal is very low at 1.3 milliamps, allowing for long battery life. All you need to provide is solder, soldering iron and a few simple tools.
The Thunderdrive Deluxe Overdrive Effects Pedal Kit | Amplified Parts
