Threshold Fet Ten/HL E power connectors?
Can anyone please identify the power jack and plug used in the Threshold Fet Ten E power supply? I'm building a larger power supply and don't want to cannibalize the factory power supply. This is the larger detent type with locking collar, compared to the mini-XLR.
Thank you,
Greg
Well, I gather this is called a push pull connector, but after looking at thousands of photos and drawings of similar connectors, I've yet to find this part or a replacement. Can anyone lead me in the right direction?
Cheers
Thanks, Pars, but those aren't equivalent.
Good news is I was able to dig into the cabinet and pull the cable from the existing power supply; these are Tajimi connectors. For anyone else who may be interested, they are Tajimi PRC03 in zinc and PRC04 in aluminum.
Now to see if there is a local supply...
Thank you both.
