Any opinions on the use of threaded inserts versus T-nuts for driver mounting? I'm mainly concerned with strength; I've worked with both but have no way to evaluate their relative suitability.
To be more specific, my substrate is MDF and the thickness is 2.25". Fasteners are 10-32.
BTW, I discovered Boltdepot.com today. They have good prices on sometimes hard-to-find items such as black oxide cap head screws and short (1/4") philips machine screws.
I would vote for inserts. I can't begin to recall how many times t-nuts have pushed out when I have been screwing in the drivers, and it always seems to be on the last screw.....
Andrew
Andrew
Here is one post I found. It doesn't really answer the question, but there is at least some opinion that the holding power is equivilent.
http://www.bt3central.com/forum/topic.asp?ARCHIVE=true&TOPIC_ID=4763
The Rockler/PE style barbed inserts are recommended for weak substrates like MDF/pine/particle board.
tiroth said:Any opinions on the use of threaded inserts versus T-nuts for driver mounting?
Over both of those, I prefer Parts Express Hurricane nuts. They are strong and they don't back out like some other T-nut styles.
personally, I prefer T-nuts. I've used inserts a lot and they tend to be a pain to drive in cleanly, especially in mdf. Other T-nut type fasteners, like the 'hurricane' type mentioned above, are even better.
- Threaded inserts versus T-Nuts
