Thoughts on this input selector PCB? How can I add volume control?
Questions about input selector
IY audio passive preamp
I'm trying to replicate this. Can someone help me understand this part:
This passive preamp use a 4-port, 3-position switch. All channels' ground signal is switched with the main signal. The grounds of each channel are isolated, therefore ground loops between equipments are eliminated. Also, the noise from one source cannot get into another.
Specifically the bolded portion. Do the ± go both to the 3 position switch from each input?
Thanks,
Alfa
The same switch. You have four poles: two for signal, two for ground. So with a 3-way switch you can switch between three inputs. I still don't understand what is puzzling you. If switching the ground is too complicated then use a 2-pole switch and just switch the signal - as most people do.
General rule in DIY: if you don't understand it don't do it!
