I like to try SI but without hassel of trying to change batteries all the time. I also don't want wallwart.
Can I use this? Regulated 13.8VDC, with continuous 3A, with surge of 5A.
http://www.mcminone.com/product.asp...ucts&category_name=3830082&product_id=72-8140
thanks,
gychang
thanks,
gychang
It "will" work, but it's big, ugly, and linear.
Do a search on ebay for 14V adapter. It will bring up quite a few LCD monitor switching supplies, most of which are 3A or more. This is what I use on my "T-Amps" . Of course there is a plethra of other switching supplies out there you can find for cheap also.
I guess the real question is "Linear" or "Switching"?
theAnonymous1 said:It "will" work, but it's big, ugly, and linear.![]()
as u can gather I am new to this electronic stuff. Which is better "Linear" or "Switching", I am not sure what the Linear and Switching refers to...
The model above is <$25, for variety of reasons I like to avoid wallwart style (may want to "upgrade" from SI later).
I will look around the ebay as u suggested.
thanks,
gychang
A "wallwart" is usually just a very small transformer with rectifiers and smoothing caps, no regulation. Not very ideal.
The linear supply you posted is very inefficient and heavy and "wastes" the unneeded power from the transformer as heat.
A switching supply works very similarly to the SI amp itself. They usually have >80% efficiency and are very lightweight compared to a linear supply. Many people consider a switching supply an ideal power source for a switching amplifier.
I'm sure someone better at explaining things will chime in.🙄
that's very helpful, so I will look around the switching PSU, particularly interested if voltage/amp can be variable (plan to upgrade later time to another t-amp).
1. Anyone know a "cost-effective" (cheap), switching PSU, perhaps with adjustable output?
2. If not, would really appreciate switching PSU that will work with SI.
thanks,
gychang
Here's a nice power supply for a T-Amp, cheap too.
http://www.bgmicro.com/index.asp?PageAction=VIEWPROD&ProdID=12293
12V, 3.3A, regulated SMPS.
preiter said:Here's a nice power supply for a T-Amp, cheap too.
Yes, that would be a very good start. I have not heard that supply, but it looks similar to the Trends supply. It's a good and cheap place to start. Later you can look for upgrades and you will have something to compare them to.
So, switched is better than linear? Wikipedia claims that cheap switching psus may generate electromagnetic interfence, but otherwise switched seems to be better suited for this purpose. So, could EMI really be an issue?
It's a switching amp. There is EMI a-go-go inside. 😉
One would think that a switch mode supply might sound bad with these amps, but it's just not so. Most of them sound good, some sound very good.
But a good linear supply also works well, and even batteries with caps will sing.
It's an easy modification to play with. If your system is up to it, you will easily here the difference in power supplies. The are, after all, half of amp.
Which type of power supply gives the best sound quality for less than $300? Wouldn't a battery powered unit provide the cleanest most isolated juice😕
Hi
Probably yes, but if supply is not weak (powerfull enough) you shouldn't hear any diffrence between all of them, but battery is probably best
rajacat said:Which type of power supply gives the best sound quality for less than $300? Wouldn't a battery powered unit provide the cleanest most isolated juice😕
You don't have to spend $300.
Battery is not always the cleanest.
Battery is the most isolated.
I am little confused about the battery, is there a certain audio battery? or car batteries (has to have right cable) also work?, seems like it would have to be setup to recharge.
Is there a website with a particular battery with recharge capability built in for a reasonable price?
thanks
gychang
- Class D
- this work for original SI?
