Sorry for the bugging !
But I must to calculate the power thermistor for inrush current limiter in Aleph3.
But I suppose it would be faster to ask it in DIYaudio.
So for the thermistor what is the Impedance at 20°C.
It's N evolution ? 😕
And others specs for his parts...
Thanks alot !
Thanks alot !
Soory for the disturb, I found this in a hole on the forum.
I'm unforgivable.
25 Ohm at 25°C
negative progression of impedance with the rise of the temp.
And a macx current of 10 Amp (obvious it's my room fuse value)
Sorry ! Sorry ! I will never do this again
I'm unforgivable.
25 Ohm at 25°C
Miles,
If I've not mistaken, CL-60 is at 10 Ohms/25 Deg/6A, possible replacement is SurgeGard's SG27 or 40 , see... www.rtie.com/ntc/sgspec.htm
