Thermaltronics Tip advice
Hi, I've got a Thermaltronics TMT-2000S-K and two tips-
K60BV004
K60MF003
These are tiny sharp tips. I normally solder at 320-350C so thought these (K 60 series 325-358C) would be good general purpose tips.
I was surprised at how localized the the heat from these tips comes out, for example if you try to connect a wire to connector (RCA or XLR) the solder on the wire melts but the connector does not get sufficiently hot. I think these tips would be sufficient for PCB work or tiny items but not general purpose.
Before I waste money on tips- can someone recommend proper more general purpose tips for connecting to larger items? Say one for thick wire to RCA/XLR connectors and also another tip for use with speaker connectors/ binding posts which need to be heated up quite a bit?
Tips are here (K P and S series in left hand margin):
Thermaltronics Soldering: Products > TMT-2000S Soldering Station
"I was surprised at how localized the the heat from these tips comes out, for example if you try to connect a wire to connector (RCA or XLR) the solder on the wire melts but the connector does not get sufficiently hot. I think these tips would be sufficient for PCB work or tiny items but not general purpose."
Try using more flux.
Small sharp tips are useless for DIY electronics work as they don't have the required heat transfer surface area. I use a 2.4mm spade tip on my Weller iron at 700F. For big connectors and other heavy stuff I use a 5.6mm screwdriver tip, again 700F. I would never go above 700F, if the heat is soaking away then you need a bigger tip not a hotter one.
