Hi all,
(Tale from a audio mod noob who got interested reading all those stories about the T-Amp).
After a long long wait, yesterday I finally received my Sonic T-Amps.
I hooked them up to the regulated 13.8V 6A amp sat down and started to listen, pretty sceptical I admit.
At first, I thought they were a little dry and 'sketchy' in the high and mids, but after a short while everything got seriously better.
These things really ARE amazing! They are extremely transparant, excellent in the lows, very nice good stereo field, amazing sounding metal sounds (cymbals, strings, etc), ah well, no need for another review here 😉
But I just cannot believe this! I found myself frantically searching for those great sounding cd's like it was the first time again listening to a good sounding setup. Simply amazing. The dynamic on my Hepta Springs is unbelievable. I use about half of their power which is more than enough power using this PSU.
I didn't even replace the standard speaker output terminals yet, so I had to use only 1/3 of my Monster Cable thickness to get the cable in. Nevertheless it sounds amazing! I phone everyone I know and the have to hear this!
I have a great sounding Cyrus amp at my disposal which I like very much. But the Cyrus brings something to the sound (too much 'placement' or something), and this you have to like. Depends which music you listen to as well. But I find the T-Amp just sounding better! You just forget searching for the amps sound and emerge in the music. Which is the point I guess.I haven't felt with a new piece audio equipment in a long time!
Just curious: what do the T-Amp mods mentioned on the excellent forum would bring extra ? I don't have the feeling (even with the unmodded speaker clams, which I will fix!) that I want more? I'm talking about pots/caps etc.
dgo said:
Just curious: what do the T-Amp mods mentioned on this excellent forum would bring extra ? I don't have the feeling (even with the unmodded speaker clams, which I will fix!) that I want more? I'm talking about pots/caps etc.
Doesn't anyone have anything to comment on this?
See the thread entitled "Sonic Impact 5066 Parts List & Modifications" from 2/03/05 for insight on modifications and parts.
You *will* hear a difference.
Have fun.🙂
Have fun.🙂
ohenry said:See the thread entitled "Sonic Impact 5066 Parts List & Modifications" from 2/03/05 for insight on modifications and parts.
Have fun.🙂
Thanks ! I'm having loads of it already!
And I didn't look thru that thread yet, so I will!
You mentioned that '...At first, I thought they were a little dry and 'sketchy' in the high and mids, but after a short while everything got seriously better...'
What's according to you is 'a short while'? 'Cos my t-amp sounds a bit harsh in the high and mids too. But the problem, I suppose, is that the t-amp I own is completely new. I've listened to it for about 10 hours only.
How many hours of playing it does require to reveal itself???
Some say 50, some say 100.
I found the biggest improvement over the first 10-15 hours and gradually getting better after that.
Also, I think it has to do with getting accustomed to the natural sound the amp gives. It still sounds a bit dry and crispy sissling compared to what I was used to. (especially very appearant with metal symbals and clean vocals)
But in my opinion it is just transferring the sounds ultra transparant compared to the amp I was listening to. I've got a feeling I'm hearing the frequencies the way they were recorded. The dryness(or should I say cleaness) and crispyness for me is proof of it's excellence. I just wasn't used to hearing this type of clear transparant sound because my other amps simply can't offer it. And I absolutely love it.
Well DGO,
A few weeks ago I also received my two T-Amps and I also was amazed by the sound of it. I am not an experienced solderer and modder, so for me it is a risk to solder things upon such a small print.
But I just orderded the EB-TA2024 evaluation board from Tripath, which has a few advantages over the T-Amp (see under the TA2024 topic).
opentop said:Well DGO,
Hello opentop,
I'm not sure what you're trying to say... I'm not an experienced diy either, and up til now I've been running the SI unmodded, I just hooked up the regulated PSU. I did however order one of Art's excellent alu housings ( http://mywebpages.comcast.net/ampbox/ )
which, next to looking real stunning, will supply better input/output terminals and volume pot.
But for now, it's still the stock SI 🙂
And, apart from the clipping behaviour, (obviously) I'm extremely content with the sound quality.
What's your experience and setup?
I'll look into the evaluation board, thanks. I'd be interested in your comparison with the stock SI.
I'm also building the AMP3 kit from www.41hz.com I suspect this will have a better clipping behaviour than the SI. The soldering is quite a challenge though for a diy beginner like me, but I'm almost finished.
Hello DGO,
What I am trying to say is that I am very pleased wity the T-Amp. It sounds great and very clear, open, detailed. I use it in the following setup: TEAC vrds10 Cd-player, Audiomat tango 2.0 DAC, Behringer 2496 DEQ Ultracurve, Duson C100 pre-amplifier and Magnepan 0.5 speakers.
But... reading all the articles about the T-Amp I learned that is still possible to improve the sound through modding. But like I said, I am not experienced in modding. And looking at the size of the PCB inside the T-Amp I decided to skip that option (maybe I will mod in the future but I first want to learn about electronics and I want to practice soldering before I begin).
Then I read about the evaluation board with the same Tripath-chip. It has the possibility of connecting your speakers with bananaplugs (instead of crappy binding-posts), it has a double RCA audio-input (instead of mini-jack). And the bass roll-off is gone thanks to a different input cap (don't ask me about the technical details, I am a newbie in this field).
My conclusion: by buying this I won't have to mod to improve the sound. And the sound of the T-Amp is already great.
opentop said:Hello DGO,
Glad you like it too. What's your experience on clipping /ringing in your setup ? nice system ! What's the efficiency of those speakers? What amp did you normally use?
opentop said:But... reading all the articles about the T-Amp I learned that is still possible to improve the sound through modding. But like I said, I am not experienced in modding. And looking at the size of the PCB inside the T-Amp I decided to skip that option (maybe I will mod in the future but I first want to learn about electronics and I want to practice soldering before I begin).
I think we can shake hands there on experience. It's the same reason I didn't try out to mod thing yet. But also, I'm not experiencing that I'm missing something. Like I said before, the only 'problem' I have with the SI is the clipping behaviour.
opentop said:Then I read about the evaluation board with the same Tripath-chip. It has the possibility of connecting your speakers with bananaplugs (instead of crappy binding-posts), it has a double RCA audio-input (instead of mini-jack). And the bass roll-off is gone thanks to a different input cap (don't ask me about the technical details, I am a newbie in this field).
That looks like a good call. For the same reasons you mentioned I bought one of Art's chassis (and it looking good). But I won't have better input caps. (With people so positive about the result, I'd like to try it out)
If my amp3 (2021B based) project doesn't succeed I think I'll go your way. I'm interested in the 2021B evaluation board as well.
I'm really beginning to wonder how the other chips of Tripath sound.?
I experience no clipping at all. But then again, I use a pre-amplifier.
That said, I once connected the T-Amp directly to my cd-player. Again there was no clipping, though I had to turn up the volume to approximately '2 o' clock'. I play in a small room (only 3 x 4 meters).
I don't know the effiency of my speakers. I only know that the next model Magnepan developed, the 0.6, has an effiency of 86 dB. That's not much, but apparently enough.
Before the T-Amp I used a Audio Analogue Donizetti power-amplifier (2 x 50 W).
Good luck with your Amp3!
Good for you that it doesn't as it's not pretty when it does.
With very dynamic music, the t-amp will start to distort heavily and
clip eventually when driven to its limits. This especially seems to
happen with overall loud, dynamic music on sustained notes (like a
violin in full blazing orchestra striking out in a solo or on very
dynamic sustained vocals)
At my setup approx. with the dial from 1 o'clock and beyond,
depending on the input signal, I reach clipping levels. That's at 8 ohm 89dB Hepta's.
When you reach the clipping level, seems to depend heavily on the
efficiency of the speakers. The people I've heard where it doesn't
clip or a lot less, use very efficient speakers. Perhaps your speakers
are more efficient than you suspect?
I don't understand what the influence of a pre-amp on the clipping
level of the SI would be, can you explain please?
By the way, I'm listening in a fairly smal room as well (6x4) and it's
quite easy to stay below clipping levels, so it really isn't a big
problem except with some music parts.
Some good measurements at Michael Mardis' site about the clipping
behaviour http://www.michael.mardis.com/sonic/sonic3.htm
[/QUOTE]
opentop said:Before the T-Amp I used a Audio Analogue Donizetti power-amplifier (2 x 50 W).
How does it compare to the SI?
[/QUOTE]opentop said:Good luck with your Amp3!
Thanks! I'm waiting for some components and then I *hope* it will
play 🙂 Can't wait to hear it.
dgo said:At my setup approx. with the dial from 1 o'clock and beyond,
That sounds about right. The onset of clipping on a stock SI should be right around 1 o'clock with a 1Vrms sine wave input. From my experience those are pretty good listening levels with 89dB speakers in a small room.
I don't understand what the influence of a pre-amp on the clipping level of the SI would be. Can you explain please?
Well, using the SI this way, it serves as an power-amplifier (I know, it sounds strange with this little bugger). The pre-amplifier give it extra juice, so I can play louder, with the volumeknob on maxium. I control the volume via the pre-amplifier.
I am not sure yet (because I use it in a setup wtith pre-amplifier, DAC and Ultracurve). Bit I like to think there's a little more detail with the SI.How does it compare to the SI?
opentop said:
The pre-amplifier give it extra juice, so I can play louder, with the volume knob on maxium. I control the volume via the pre-amplifier.
This is often the case. A buffer stage (e.g. preamp or line driver) will make a power amp sound better, often louder or stronger. If it does, then you can suspect that your source is not strong enough to drive the input of the power amp. Not uncommon.
But the preamp can not raise the power amp clipping threshold or output power, only a better and/or higher voltage power supply can do that.
FWIW, the stock Sonic has a somewhat low input impedance meant to be driven by a headphone jack. Some CD players may sound a little weak when driving it. YMMV.
Okay, thanks for the info. But like I said earlier, I haven't experienced any clipping whatsoever. My listening room is 3 x 4 meters only. So I don't have to play loud: with preamplifier, the volumeknob of the preamplifier on 10 o' clock, with only the SI, the volumeknob on 12 o' clock (higher is too much for my ears).
I just finished the first round of mods on one of my SI boards and just wanted to give a few impressions on the sound. First the mods:
1. Removed the 100 pf caps to ground and left the pads "open".
2. Removed RO1 and R02 and left their pads open.
3. Removed the volume pot header.
4. Replaced the 330uf filter cap with 660uf panasonic from Digikey.
5. Removed L1 and L2 and jumpered the pads.
6. Removed C3 and C4 and did the same.
7. Ran 2.2uf poly's to the audio input thru holes where the volume pot header used to be. I left the other two legs of the poly's dangling off the edge of the board.
8. soldered the remaining legs of the input caps to the wipers on an Alps blue velvet 50K pot.
9. Replaced R4 and R5 with 20K res.
10. Replaced all stock wires with 22 guage stranded copper wire.
11. Added a "Mexx" heatsink
I haven't had a chance to box this thing up in a chassis yet but I should be getting to that in the next day or so. I mainly wanted to do a smoke test prior to mounting in a chassis but It sounded so nice that I decided to let it burn for awhile.
I ran the SI off a 12V SLA 7AH battery that I scrounged from a defunct ADS burgler alarm that my condos previous owners left behind.
My first smoke test was a pretty intense moment. I hooked the modded SI up to an el-cheapo bookshelf system that I recently inherited. The speakers are four ohm'ers that sound like everything is being played thru a bowl of oatmeal.. so I figured no big loss if I blew 'em out during the test. I also ran a mini stereo jack to RCA adapter cable from the headphones jack on this system to the SI.
Powered everthing up...no smoke! but no right channel 🙁 . So I stopped and powered up my O-scope and did some checking around. With the board powered down I inserted a .8 volt signal into each of the input caps and managed to trace the problem to R4...yep, bad solder joint. So I resoldered that puppy in and fired the amp up...Good sound from both channels.
So I unplugged it from the cheap bookshelf system and hooked the SI up to my Dynaco A25's. I fed the outputs from my Technics CD jukebox into the SI.
The sound at first was harsh. The sound was very detailed and had pretty good bass but had a certain "airy" or "grainy" quality to it. I was playing my Best of Queen CD and Freddie Mercury sort sounded like he was singing into a tin can. Initially I was a little disapointed but I decided to let the amp burn in awhile. I came back after about four hours and most of the harsh quality was gone...not all...but definately better. I left the unit on all night and by this morning the amp was sounding very nice indeed. Can't wait to get it boxed up and get started on my next project! 🙂
T-Amp volume pot bypass
Hello, the T-amp; why pay more for an amplifier ?
I wish to use it as a power amp (the smallest one I have ever had !) and would therefore like to remove the volume pot. There are 5 wires going to the pot. Any ideas on how to bypass the connections ??? thanks to you all, its my first time up here !
- Class D
- The T-Amp really IS amazing!
