"The Practical Preamp"
This is a subject I tend to rotate round to every few years. The latest spark is becasue I've just spent the day restoring a couple of old 1970's Rotel amps. Unfortuately one is looking positively past its sell-by date, which always begs the question "why don't I put something funky into it". Power amp replacements are straight forward, preamp replacements are more tricky. Anyway...
What I'm think of is a modern, practical pre-amp which has:
  • volume control
  • source select
  • line-level inputs
  • option for front-panel control or remote control
  • both digital and analogue inputs
  • option for RIAA/phono
I'm not talking about audio-purism here: it needs to be practical, usable and affordable.
QUESTION: Am I covering old ground here?
Using semiconductor volume controls and source-selects gets rid of exotic pots/switches and also allows remote operation. No obsure components which can't be bought for Digikey/Mouser. Almost certainly require a microcontroller to handle the interfaces, but thats pretty straight forward (my posion is TI's MSP430's - I've already done a remote control interface for one using an AppleTV remote - very obtainable). The question is then to handle the rest of the system?
THOUGHTS?
There is one option which would make for a very simple circuit, but I suspect I may be burned as witch for even suggesting it: using an Audio Codec chip and 'normalising' everything into digital for processing!!! Something like the Cirrus CS4245: it'll take 6 Analogue Inputs (line level), 1 Digital Input, level balance, volume balance, mute and protect. The only issue is that the audio will be chopped into 24bit/192kbps then reconvertered
6x Line In >> CS4245 >> Audio Out
1x SPDIF Rx >>
Remote/Front Panel >> uC ^
To my mind, thats a 3 chip solution (Codec, uC and SPDIF Reciever) to cover some very substantial functionality
IS THIS MADNESS?
Just collecting ideas and thoughts. If I pursue this through, does it value anyone else?
Mat
Hmmm, after reading the responses, bit more research needed.
If I head down the digital route, then actually the ADAU1701 is a brilliant fit: it almost does bloody everything in one chip. However, as this is starting to feel like more work than art, then a TDA7440 would give a good analogue solution (with uC strapped to it).
To be clear, the reason I'm doing this as a 'compromise' design is to have a standard building platform to upgrade old amps with. Given my work so far with the Rotel, I've got a plethora of choices of power amp designs (including a Tripath board sitting in the shed which is tempting), but most of the failures in the old Rotel are preamp/signal path related. (some previous DIY-Audio'er decided to replace the electrolytics, but has badly fobar'd the PCB in the process).
