I want to make a tread with some gatherd info on psu`s for digital devices. -clocks, cd players, dac`s-
So to speak -low current-, high stability, and low noise factor psu`s with some info on them.
So go ahead, post your psu and plz specify where u used it, whats so good about it, a schematic, and additional info. -is it shunt regulated?, did u experiment with caps? What regulator is used? All that gives a clear idea of what the psu is all about
Ofcourse post only what u found to be the best psu for that specific digital device. No need to post every psu u ever made.
Happy posting.
Rikkert
Happy posting.
Rikkert
Those threads exist already in many aspects and another one repeating the same info does not make too much sense IMO 😉
Please use the Search function and reopen an old thread about this instead when necessary after reading all posts. hint: Fmak has posted quite frequently about this subject with very useful information.
Or you can read all the info you need about the subject and save it in one Word/Abiword/OpenOffice file or even better; make one PDF containing all the info you need. I can recommend OpenOffice because documents look better and it has the ability to save documents as a PDF file. BTW OpenOffice is free and available in the dutch language ( www.openoffice.org ).
Jean-Paul\ has a youseful answer for u 😀
