I am a bit surprised that there are no Creek Audio tuners mentioned. T40 was a good tuner, and later T43 was a better one (OK, I would say that, as I've designed the second one 🙂 ) .
Cheers
x-pro
Cheers
x-pro
Hello X-pro, It sounds as though you're still a pro. No Creeks because I've not had one, YET. I do use a Creek OBH-12 as the A/B switcher. Tape out as to bypass the level control. Hope to listen to a Creek tuner this year. jim...
3moons said:Hello X-pro, It sounds as though you're still a pro. No Creeks because I've not had one, YET. I do use a Creek OBH-12 as the A/B switcher. Tape out as to bypass the level control. Hope to listen to a Creek tuner this year. jim...
Hello,
I am no longer working in audio design - so that is why the "X" 🙂 .
However it would be interesting to get your opinion on T43 or T50 (which still uses my design of the tuner board, as far as I know). Apart of these 2, the same board but assembled in China and with lower grade components is used in Cambridge Audio T300 and T500 (I think) . Cambridge Audio bought the design from Creek... .
This design is interesting as it is completely different from anything else on the market (or made previously as a home tuner). The main board is build around top-end Philips chipset for car radios and uses completely synchronous (from a single crystal master clock) dual conversion receiver both for FM and AM.
Cheers
x-pro
Hello again, If you didn't notice while at our tuner info site, we have a FM tuner discussion group of 1750 members world wide. All kinds of folks from engineers to ones who need to know the value of bulbs in their tuners. Link below if you wish to participate. jim...
http://groups.yahoo.com/group/FMtuners/
So I presume you have your very own high-quality FM transmitter inside your house that you are feeding with better-than-CD-quality material? Otherwise "better than any CDP" is just about physically impossible for quite a number of reasons, most of them relating to the inner workings of radio stations (notably processing) and radio propagation (notably multipath). Even if we're ignoring all content beyond 15-16 kHz for now. I've never seen any tuner spec'd at a stereo SNR of more than 90 dB anyway - and that's entirely academic once the slightest bit of multipath comes in.
Congrats on resurrecting a 10-year-old thread btw. 😛
- Analogue Source
- The latest FM tuner Shootout review is up
