the best mid-woofer?
I want to start building my diy project ,a BMTMB combination,using excellent drivers,dynamics,transparency,capable to play very loud.
Which driver do you suggest?I think of peerless HDS134,or 182.Are the scanspeaks 15w..,or 18w.. much better?😕
ANY commercial loudspeakers using these peerless units?I already know many using scanspeaks.
--BMTMB combination
Money is no object right:nod:
Here goes;
B = Lambda TD15H
M = PHL 2520 8" midrnage
T = SA8535 stage accompany planar (settle for Esg1)
M = PHL 2520 8" midrange
B = Lambda TD15H
Estimated cost US;
Two SA8535 tweeters = $1200
Four PHL 2520 midrange = $700
Two TD15H = $400 (apollo version $800)
$2300 / pair (apollo version $2700)
Money is an object:bigeyes:
If you heard one SA8535 + one PHL 2520 + one TD15H,
it would knock your socks off. It would sound like a live
performance provided that you give each driver some
power. This simple 3 way rules. Cost = $1950 / pair
Non Dr. Insano idea 😎
See bottom of page.
http://www.e-speakers.com/
"ESg3 / PHL3451 / Lambda SB12"
Wild Card -> Rick Craig ExcelArray design 🙂
... ask for pics on madisound.com
The best mid in the world IMHO is the ATC SM75-150S soft dome, mate this with a Seas Millenium tweeter, and maybe the Volt RV3143 woofer, and you would have a system to knock your socks off. Not cheap, but very very good.
