THD with Raspberry DAC hats
For a streamer based on a Raspberry 4, I bought two DAC hats - a HifiBerry DAC2 pro and an AUDIOPHONICS DAC I-Sabre ES9038Q2M.
I measured THD and noise on both hats with a Motu M4 and an E1DA COSMOS ADCiso. Software: REW and AudioTester. For playback I used LibreELEC and Moode. The test signal was a wav file with a 24-bit sine (sampling frequency 44.1 kHz, level 5 dB below FS).
While the noise floor was quite low with both DAC, I was a little surprised with the comparatively high THD value of around 0.04% for both hats. For comparison: the distortion of an old Roland duo capture EX DAC (same measuring setup) was more than an order of magnitude lower (0.003%) and the value published by ASR for the AUDIOPHONICS converter was even lower than that. Both ADC and programs delivered very similar results, BTW.
OK, 0.05% is (for me) not too bad, but I'm interested in what the reason for the high THD values could be. Any ideas?
Peter
I don't know the reason in your setup, but here are my observations:
Each ADC has an optimum input level range. Anything above will quickly increase THD.
USB powered devices can spoil the signal. I use a home-made Y cable. The D- and D+ go straight (so does the GND/shield), but the 5V (red) is disconnected, and comes from a power bank to the ADC.
It is best to perform an analog loopback test to verify clean noise floor (signal OFF) and low THD (signal ON).
I also use an USB isolator that is a tiny board for signal pass-through and galvanic isolation.
Now I have a medium quality sound card (Sound Blaster X-fi HD, SB1240) with a -130 dB noise floor and 0.00050% THD in loopback.
Lastly, the LED desk lamp caused serious interference until I turned it off.
I am not sure but the RPi might emit stray field to the HAT, there might be a ground loop, etc. I don't like sensitive audio circuitry in the vicinity of digital electronics.
Reactions: Markw4
Thanks for your reply.
I have done some more tests with the AUDIOPHONICS DAC and found that - as you mentioned - the output level is rather critical. I had to reduce it to 250 mVeff to get a THD value of 0.005 %. THD+N was 0.0065 %. That's ok for me, but an USB DAC like a Topping D10 would have been the better solution (with a similar prize). With an additional case on the desk, however.
Peter
Reactions: trungdtmc
