Terminal Block Source for Blank PCB
One of the allures of going the DIY route to many is having the control over the partaking that GI into your equipment. I get that. And although I'm a newbie, I find it interesting sometimes to look at the datasheets of components that I am considering - even if I don't understand most of what's on them.
BUT... I am trying to finish my mouser order for a gainclone kit (blank PCB) and I'm at the point where I want to slit my wrists because finding the terminal blocks has been EXCRUCIATING!!!
I need two 2pin blocks with 5mm pitch, a two 2 pin blocks with 8.5mm pitch, a 3pin block with 8.5mm pitch, and a 3 pin header with 2.54mm pitch. Can anyone help with a source? Preferably in north America. Part numbers would be great. This is something i would like to be done with.
Try here at digi-key
select pitch and number of positions, click 'in stock' (you will not be special ordering thousands of them!) and search.
I hope you meant 7.5 mm not 8.5 mm. Of the over 10000 at digi-key, none are 8.5 mm pitch. If you really do need 8.5 mm, then well, talk to the eclectic individual who designed that PCB.
That is precisely the problem. There are a combined zero 8.5mm pitch terminal blocks in all of Digikey, Mouser and Ebay!!! I double checked the BOM and it does say 8.5m pitch.
I just sent an email to the guy I bought the PCB from. FWIW, it's the Jim's Audio gainclone board from this thread. I guess I should probably post a question there too.
Thanks for your help.
