I might be able to buy a cheap Tektronix TDS2022 with a cracked screen.
Is it possible to replace the screen to get it to work again, or is it a lost cause and only a waste of money?
The scope itself seems to be pretty expensive (in working condition) at eBay and such.
Hello,
LCD display part number is 650-4349-00 and is only provided by Tektronix.
So, I'm afraid it won't be cheap.
Ok, thanks for the reply.
I was afraid that would be the case, but was hoping that it would be possible to use some other type of screen 🙂
Sent a long time ago from a Galaxy [Tab] far far away using Tapatalk HD
The screen is an off-the-shelf STN LCD part that you can buy new from China for <$100. Once you get the unit, you can figure out the OEM part number.
