Technics SUV4X shuts down on static electricity touch
Hi
I have an earlier version of this amp with the printed and not raised Technics logo. The amp is on a wooden rack which is in turn on a carpeted floor. If I wear a certain pair of slippers a static charge is building up. If I touch the metal case of the amp near the power switch it immediately shuts down.
When it first did this I thought it was a loose power cable. It comes back on again fine if I turn it of and turn it on again and functions with no issues. DC is around 2mv on both channels, etc.
I have recently replaced the speaker terminals as the original plastic twist lock ones were loose and breaking up. I have not used this unit much so not sure if it was an issue before the changing the speaker terminals.
This is not a major problem but was curious to know if anyone has any thoughts on the matter. The initial solution is not to wear static creating slippers!
Something in the logic section is getting zapped with a spike - I'd check all the case screws are tight and bonding the parts of the case together with a good ground - all the metalwork in the case should be low impedance to mains earth, forming a Faraday cage.
Try not to zap it as there's no guarantee it will survive indefinitely.
Nylon carpets are a real issue for electronics, some textiles add a small proportion of carbon fibre to address this, and there are commercial anti-static sprays available.
Just to add to Marks post -
A "soft zap " can cause a minor fault in a chip which doesn't stop it working but cause unusual faults to occur --this is a proven fact.
While I worked for BT the zap cords had 2 Megohm resistances at either end.
