Technics ST-S4 - okay 3x capacitance power supply as no output
Hi
I have had this Technics ST-S4 tuner for awhile now. I have been moving it around a bit and now there appears to no sound output.
It has been under repair from a hifi repair store, before i got it. I noticed a resistor with a dry joint, and one cap looked suspect, i only got 1.0 on the ohm meter at lowest setting and nothing at 1K -20K ohm setting as i was comparing it to lower value silmicII i had spare. Also the legs were loose, and when i moved them it sounded hollow inside = no leaking, just appears dried out
Before buying a cap, i removed a from my spare board a 3300uf 16v cap, to put in place of the suspect cap, original value was 1000uf 16v ??
Should it be okay to turn on?😱
Hello Kerusker
I have the service manual it appears to be for Technics ST-S4T, not sure what differences it has
I have a multimeter. Its basic but has ohms, volts dc and ac, continuity, diode test. Maybe i can measure dc current? at output? not sure how
