Technics SP10
"In 1970 National Panasonic (Technics) had introduced the SP10 direct drive turntable. It was a single unit with no seperate power supply. Its speed was regulated by reading the minute fluctuations of the platter with a tachometer and correcting the turning of the motor".
It is the MK11 which uses the crystal. The above quote was taken from a history of the SP10
Will the frequency change from 60-50hz allow the use of a stepdown transformer
Hi Haydn,
The frequency change will have no effect as direct
drives do not use AC synchronous motor principles.
The "tachometer" referred to in your quote is almost
certainly referenced to a quartz / crystal oscillator.
🙂 sreten.
Tonearm
I am thinking of fitting a new tonearm to my Sp10 and there are two Jelco models avaiable on ebay at very reasonable prices. One is a 10" while the other is a 12" arm. Price difference is nominal. Which one would be better?
Vinyl die-hard
