Technics SA-202
In the process of replacing bad caps on a SA-202 and have so far replaced all caps visibly bad and corroded. Issues were both channels dropping, weak out put, and occasional R channel dropping.
After replacing bad caps, but not big output caps, still have R channel dropped with very low output with AUX input. Switched to Phono input and both channels sound great. So now I'm on to checking Jack's and plugs, but if anyone has any other ideas, I would be appreciative!
I don't have a strong grasp of circuit theory and ability to interpret a circuit diagram, however I can solder well and can read a DMM if I'm told where and what it should read. Still learning.
