hi guys, i'm new on the forum. I would need your help. I have two technics 1210 mk2, one works fine while the other after half an hour of activity gives me this problem: the pitch green light stays on even after zero, and the pitch stops working. What do you think it could be? thank you in advance
Follow the service manual schematic and you will find if it is a sensor/slider or power supply issue.
Waveforms are shown in the manual.
hello, thanks for the answer, unfortunately I don't understand much and I don't have an oscilloscope, but I get along well with the tester and soldering iron
welds look ok. I did a test, swapped the pitches on the turntables and now everything seems to work, how is this possible?
