TEAC VRDS-10 repair advice needed
Hi there,
I recently picked up my elderly father's pride and joy in the hope I'd be able to get it repaired for him. It appears to work perfectly when cold but after a few minutes of operation, the sound crackles and breaks up and then disappears completely. It comes back again if the machine is turned off and left to cool down so I'm guessing it's maybe a dry joint somewhere. I'm not an expert by any means but can wield a soldering iron if I knew where to look. Can anyone suggest what the problem might be?
Thanks in advance!
Hi there,
Thanks in advance!
go to follow thread (hints from me):
http://www.diyaudio.com/forums/digital-source/156453-teac-vrds10-wont-play.html
and perhaps to the follow:
http://www.diyaudio.com/forums/digital-source/137413-teac-vrds-10-help-please.html
http://www.diyaudio.com/forums/digital-source/53300-teac-vrds-10-service-help-needed.html
http://www.diyaudio.com/forums/digital-source/67445-teac-vrds-10-need-help.html
http://www.diyaudio.com/forums/digital-source/47949-teac-vrds-10-vs-10-se.html
http://www.diyaudio.com/forums/digital-source/141740-teac-vrds-10-vs-vrds-25x.html
Hi StirlingSteve
After the sound has disappeared, does the cd continue to rotate and the display show track no., elapsed time progressing etc.?
If so, you may well be correct about a dry joint. Your best chance of locating it may be through gentle prodding/tapping with an insulated probe of some sort during those first few minutes of operation.
