TDA8932 Aux port connection and potentiometer resistance values?
Hello, I'm building a 2 way speaker and I'll use two TDA8932 mono amplifiers: one for Dayton DSA-135 woofer, second - for Dayton ND20FB tweeter. My questions are:
1) is my [sketchy] drawing correct - to be exact - can I pair (+)pluses and (-)minuses of both amplifier inputs and connect them to potentiometer which then goes to stereo AUX port with shorted left and right channels together?
1.1) Or shall I do everything till the potentiometer the same but use a mono AUX port? Or is there no difference between these two methods?
2) What resistance for volume potentiometer shall I go for, so I won't lose any HF extension, as I've read in forums? This TPA8932 has a gain of 36db if it is important.
Thank you!
