TDA8922C asymmetrical power supply?
Has anyone used the NXP TDA8922C with an asymmetrical power supply?
Looking at the older TDA8922(25W version), the datasheet shows the part as having that capability by using a 10K and 9.1K resistor to feed VDDA and VSSA. However the datasheet for the TDA8922C doesn't mention an asymmetrical mode of operation.
I am only wanting to get 40 watts out of the chip in BTL mode using a 32 volt power supply into 8 ohms. I just want to avoid a split supply if possible.
