TDA1545 NON-OS DAC + ASYNCHRONOUS RECLOCKER by Tang WK with philips cd player saa7210 to i2s output but doues not work.
I use it in old cd player base on cdm2.0 with system clock 11.2Mhz and tda1541 as i2s transport.
I disconnect saa7220 and connect that reclock to saa7210 WS BCK and DATA output and clock to on-board 11.2 mhz oscilator . i try to connect is to my used for 3 years nos i2s dac but is only noise compare to music without that reclock device...WHAT I DOING WRONG. HOW I CAN RENEW OR ISOLATE I2S SIGNAL FROM SAA7210 BECAUSE IF I CONNECT WIRE TO CLK OUTPUT LASER HEAD GETS CRAZY. Thank for advice
