Is it possible to design direct battery powered tda1541 dac without any voltage regulator?
Using nimh or lipo batteries it could be possible to obtain the +-5V and -15V...
the max ratings of the datasheet are +-7v and -17v
It seems that lead acid batteries are not good, having noise, but nimh and lipo are quieter than the best mains psu.
Any experience? any advice?
Vill the voltage variance from fully loaded and empty battery move the vorking point of the TDA1541? I envisage to use the MK-8 design of ECdesign
http://www.diyaudio.com/forums/digi...ding-ultimate-nos-dac-using-tda1541a-401.html
I did many battery preamps amps and DAC output stages and i think you can't go with no regualtors, the voltage will vary to much.
Why not use regulators with batteries? there are still many advantages
regulators have feedback loop, poor transient characteristic etc...
I would like to avoid the complexity of really good regulators by using inherent silent and stable batteries.
So You should try a discrete regulator without any feedback, condesators and resistors. Simplest zener diode with bipolar buffer on output is what You need. 🙂 Zener noise will be filtered on the decoupling caps so it's not a big deal.regulators have feedback loop, poor transient characteristic etc...
http://electriciantraining.tpub.com/14179/img/14179_210_2.jpg
Instead of resistor in R1, use a jfet(BF245B), G and S pin of jfet should be connected to zener diode.
Had some CD players (TDA1545 & 1541 & 1543) with battery (dac and I/V stages).
The gain is not great and sometimes is not.
You need two baterries for a battery phantom power supply for the I/V stage, lot of 1 uF saving caps in series to have a huge power capacity quality for tanscient, some normals big caps with low esr. It's expensive.
As voltage change with the load of the battery, I think you need regulators. Another problem is the I/V stage... most of the times you need more than 12 V... it adds complexity.
IMHO and experience, the design can be better with times spent on a good regulator and a long and carefull choices of capacitors. In fact you will ear more difference with playing with caps that playing with battery vs discret powersupply.
that just my own opinion. Not an expert but spent some times on this subject with more than 20 cd players (Marantz, Philips, TEAC, SONY, TOSHIBA, Kenwood, AIWA) with trying to improve DAC and I/V stage powersupply and sound signature. I'm still very surprised today seeing good designers making the bad choices abouts caps in relation to their position in the design...
You can try for the DAC some little ears'amp battery;;; but most of the times with the same stable voltage, the cap make the difference and have to be choosen in regads to the global sound of your DAC or CDplayer... it's a set up. A Nichicon FC can be better than a Panasonic SEPC near the DAC, but sometimes it's not ! The purple Sanyo Os con give incredible result because smoother (not avialable today), and Black Gate BGNX alone have a good "mate" sound but horrible harscheness alone...mixed with a good sepc value will be amazing...and so on.
Have a look around there is a long thread regarding batteries and the fact they are not all that stable or quiet, a regulated battery supply is better than batteries alone, especially where digital is involved.I would like to avoid the complexity of really good regulators by using inherent silent and stable batteries.
- Digital Line Level
- TDA1541 NOS DAC direct battery powered
