For Sale TDA1540 DAC full set
Things you have for sale.
Selling all parts to build a high end TDA1540 DAC, selling due to having too much projects going on!
All boards have been tested and DAC is confirmed working, you just have to wire everything up and build it into the case!
Set contains:
Miro TDA1540 DAC board: PSU decoupling caps changed to Elna Silmic II, opamp sockets have not been populated.
Altera CPLD I2s converter: converts I2s to offset binary, flashed with Miro's firmware and including USB blaster
SPDIF/Toslink receiver board, with Cirrus Logic WM8805 receiver chip
2x CEN FC IV boards: great IV converters, with matched FETs, Audio Note Kaisei capacitors and Rhopoint IV resistors, tested and DC offset in the 0+-3mv region
5x Salas UltraBIB shunt regulator supplies: 3x pos and 2x neg
2x SilentSwitcher 2024 model: -15 0 +15V supplies
2x R-core transformers: with all the necessary taps, including 115V and 230V primaries
1x Hifi2000 3U case, with 10mm thick front panel: new and unused including IEC socket and illuminated power switch
Will add 2x TDA1540 additional DAC chips and unpopulated CEN filter boards
This needs to go to a good home, so asking 500€ for everything, will ship worldwide
Ask if you need some different digital input options, have some XMOS USB boards or Rpi with FifopPi Q7
