tb w5-1685 as semi FR?
The problem with crossing that high is the beaming of the midbass driver approaching that freq.
The other problem is designing an xo with bsc without adding separate components to act as BSC due to the high xo point.
Lastly, you cant say it as semi FR, cause it has a peak in the upper range that you have to deal with , Making the speaker strictly a 2 way design. A semi FR design is one that uses a wideband driver without XO with a super tweeter added to fill in the top.
