Taramps 8000.1 Schematic or Service manual
I don't have any I can post but I can try to answer any questions you have. What's incredibly important is to get the DCV from all terminals of the MCU from a working amplifier. That can GREATLY help in troubleshooting an amplifier. The rest of the components have datasheets that tell you what to expect. There is no such document for the MCU.
I appreciate the tip on the MCU. Right now I'm stuck tracking down why half of my power supply fet traces (each side) are shorted from gate to source. I've pulled MCU, IC3, IC1, IC9, IC4, IC2, and CI1 to no avail. I'm sure it's something I'm overlooking but I'm not sure what to test from here.
Seeing 220 ohms across these pads from gate to source (marked with black line)
Dmm probes are .3 ohms when touched together
The others I'm seeing 5.58k ohms
