Tape Output to Subwoofer
I have an old NAD 7020e Receiver hooked up to my tv for better sound, and I was wonering as it doesnt have a subwoofer output could I connect a powered subwoofer to the unused tape-output on the amp in addition to the speakers?
-Lyle Gordon
you cant use the tape output because the tape out put is not controled. you can do what i did lastyear. go to radio shack and buy a electronic crossover they convert speaker level input to subwoofer out put ( rca and crossed over for a sub) it has a gain and a +- 12 gain and fetures from 50hz to 120hz they work well realy well. there cheap too.
Jason
Of cours i would never think about hooking that up to my aleph's.
on the back of your nad amp there should be a pair of rca plugs they might be ther but i believe they are. they look like silver u's
( U ) whenyou pull them out.
if you look you might see them if not then you might be able to use a resister off a channel of your amp. I have tryed a resister long time ago that converted speaker level to a resonable level for the input of the sub to use. Have a look on the back of your amp and see then let me know.
