Tannoy TS12 / TS-12 Subwoofer Repair (plate amp removal)
I'm attempting to repair a Tannoy TS12 subwoofer. Audio passthrough works but the amp isn't working, I get no level from the sub. I believe based on the other threads about this sub that it's a question of replacing certain caps/transistors, but I'm stuck at removing the plate amp from the cabinet. I've removed the ten screws, but it will only come out about one inch from the cabinet, so I can't get to the spade connectors to disconnect the driver. Would appreciate help from anyone that has experience removing the amp. Does the driver need to be removed in order to remove the plate amp?
