Crossover schematic of Tannoy Saturn S10
Here is the schematic:
http://f1.grp.yahoofs.com/v1/sJqWS_...JVWZ-pcqc/TANNOY S10 Crossover schematic1.pdf
Tannoy S10 crossover schematic
Dave, i attached the jpg file.
http://www.yukleresim.com/viewer.php?file=49wjamfs9nmn1u2mq0d.jpg
S10 Crossover
Now i removed the 1.5mH magnetic core coil and preparing air core choke instead. I am using 1.3mm wire. Meanwhile, i replaced the existing 15uf cap with the poliester one.
Hi could you post this schematic again please that link is not there anymore
Tannoy S10
Dear noyan;
I need the exact values of every component in the S10 schematic, I saw the diagram you posted but I don't much understand which is the capacitor and which is the coil etc...
Dear noyan;
ysharaf,
I can read that pretty well.
Inductors = Rounded rectangles had has "mH" rating
Resistors = Sharp rectangles and has "Ohms" rating
Capacitors = 2 lines in perpendicular to the circuit, "uF" rating.
I own a pair of Saturn S10s that have the drivers dated 05/1998. My crossover diagram varied slightly from the one Noyen made. Here is mine
http://bondospecial.smugmug.com/Aud.../i-2cxBCFL/0/XL/TannoySatS10 Crossover-XL.jpg
You can see the difference from his
is that my crossover has a 2.7 ohm series resistor on the tweeter instead of his 4.7 ohm series resistor, and also my tweeter crossover cap is 2.2 instead of his 2.4.
I went on ebay and by chance, found a picture of a saturn S10 crossover from a set of speakers dated 08/1999, that had values that agreed with Noyen's.
The funny thing is that the Ebay Saturn S10 drivers measured 5.x-6.x DCR and mine measure 3.x-4.x DCR. It appears Tannoy changed the drivers and the crossovers during the Saturn production run....
Does anyone have a pair of Saturn S10s who can measure the DCR of their tweeters, mids, and woofers, and also please comment on whether you have a 2.2 or 2.4 uF capacitor, 2.7 or 4.7 ohm series resistor on the tweeter, and what build date is on the orange sticker on your drivers.
Thanks!
Steve
Thanks!
Steve
- Tannoy S10 crossover schematic needed
