Tangen Class A
Ive just got this great amlifier "Tangen Class A No5" does anybody know anything about it? The owner past away, and the relatives didnt know anything about it. So if anybody has some info, thanks a lot. What I see is 8 pcs 40V 60000uf capasistors and a huge trafo. I allso got the speakers "Tangen Monitor 8R" its 2 way bulit in a huge cabinet 1130mm tall x 680mm deep x 280mm wide approx 100kg, there is no info on these either, so if somebody know something- I will be gratefull. What I can tell, they sound amazing together with the amp!
Not the same name. IIRC "Tangen Audio" was the brand of a Norwegian designer called Stig-Erik Tangen who used to be a member here - at least 100kg speakers and big class A amps sounds like what he would do 🙂
His account is disabled and I don't see any contact info anywhere but maybe someone else can help? As far as I know he is still active on a couple of the nowegian audio forums.
Reactions: huggygood
  • (Mangler emne) (2).zip
