Tang Band W8-740C box design help
I'll be placing a W8-740C in a 1.08cu ft external (9.5x7.875x25 -- .75" MDF) cabinet and would like to know what length and diameter of port would be required to get a decent response out of this setup.
I can model it all day long in winisd and unibox but really have no idea what optimal 'tuning' is for HT nor what anomalies i should be looking for while designing such a sub.
Any help with this setup would be greatly appreciated, thanks!
Unless you live in an apt. or this is for a computer system, it's totally inadequate for HT. Optimal tuning would be ~18Hz, which means you're better off leaving it sealed and accept the meager output since the vent will be larger than the sub.
GM
