TAM power transformer pulled from EL34 PP
TAM power transformer pulled from EL-34 PP stereo amp.
Primary: 120 and 240 vac primary taps.
Secondary:
HV winding is 350 vct (175-0-175), the amp was biased at 62ma per tube x4.
6.2 volt filament
30 v bias tap for fixed bias.
40 vct winding for bipolar supply.
The amp from which this was pulled used a bridge rectifier for 450v nominal B+ and it used the bipolar windings for a solid state front end.
I’m thinking $50 plus $14 for flat rate shipping conus.
