Talema 70053K (15v 15VA)
Joined 2018
I have a box of these and can let some go.
10 are available.
Used in a good few projects on here....Whammy PSU, Carl Huff PSU to name a couple.
£12 each. Post on application. Will be a small parcel I guess.
Yes, one of the rare real quality devices one can still* find. I design PSUs with them. One point of attention is not to use them at the outer power limits as their heat exchange with the environment is of course less good than that of open types.
Some tips: since they are broadband always use mains filtering at the primary side. At the secondary side it pays off to do CLC filtering. They are not only good in 50 Hz so to speak and this goes both ways.
*There was some electro gossip over there telling that some manufacturers will stop producing transformers because of worldwide demands with regards to required power efficiency.
