TA2024 battery and power supply
I'm a newbie and looking for some advice on a project. I am taking a vintage radio and replacing the old components with a TA2024 amp, bluetooth module, 2x 4" full range 4ohm speakers. I would like to be able to run this with a battery so its portable, but be able to charge the battery with a standard power supply and still play it while charging. Can anyone give me some advice as to the best battery (would a 11.1v lipo or 12.8v liFePo4 ~2000-3300mAh have enough power) and also what I can use for a charger with this configuration? I'd rather not have to tote around a smartcharger, so would a standard 12VDC, 2A regulated wall charger work?
No, you need a charger. You can get balance chargers that run on 12v. Split the 12v to the amp and charger.
When using a switched DC socket (3pins) the connection from the battery to the amp will be cut when the boombox is plugged in.
Barely, it probably won´t even turn your amp on because of the start up current. And if it would, it won´t last long. Get a lithium pack from Hobbyking. How long are you wanting to play on one charge?
I don't think there is a wiring diagram available for this setup. I can 'paint' one together if you want. Try it yourself first.
Thanks Lutkeveld!
That charger looks like its small enough, and the price point is excellent. I can pick up the DC in socket at RadioShack (The Source here in Canada).
As for the lipo, what specs should I be looking for? 11.1v.....?
I will work on a diagram and post it once I have it done.
3 in series (3S), with li-ion having a cell voltage of 3.7v that will be 11.1v indeed.
For capacity: take the time you want to play on one charge and multiply it by 0.35 (power usage TA2020 on full volume). That will be your capacity in ampere hours (Ah).
